Shaved Door HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2006, 12:04 PM
Shaved Door HELP
My driver side front and back door are shaved and have a shaved door kit on them they wont open with the remote i have to crawl in through the side to drive the car how do i fix it???
please help
Old 10-02-2006, 05:03 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Do they operate manually?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-04-2006, 03:52 PM
no you have to use the remote i cant even open them from the inside
Old 10-04-2006, 04:47 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Then the first step is determine that the RF unit is getting proper POWER and GROUND..and is programmed to the remote fob...
IF that is good, determine if it has a MCR or a master control relay..If it does, Is it firing (going Click, Click with the fob) If it does not check the RF unit for a relay control output..If it does, Check the Contact input for power.
If that shakes out..
Isolate each pop solenoid, Determine that they are in fact 12 volts..then jumper each to a proved power and ground..they should open on red to red, black to black, and close on red to black ..If they don't do that..you have some bad solenoids OR major mechanical issues with the linkage..
If the Solenoids DO pop, and the the RF unit has power and ground, but no power in-between .. you have a defective unit..send it back for repair/replacement..
BTW: you might want to consider a few things here..ONE: Install an Electrical hidden pop switch in case the The Fob has a dead battery in the middle of the sultan sink..and TWO : Install a mechanical hidden pop cable to open a door in case the battery goes FLAT dead..
Doc
Innovations
Old 10-04-2006, 05:33 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I have remote doors on the Elky.
The door handles were left on just 'cause I thought it looks a bit authentic, however, they are inoperable.
My remote will open the doors or roll the windows down.
Also in the eventual event of remote failure, the doors and windows can be operated by a key.
On top of that, there is an access switch for each door/window hiding elsewhere in the car, accessable from outside.
All of these are operated by separate dedicated circuits.
And of course---emergency mechanical, again HIDING, under the car.
I also wired a switch in to disable the remote.
Yep, I know, overdone, but I have no desire to have to break into the car, in the event of an electrical failure.
Bryan
(Docvette)
This has happened to me--internal relay failure--after sending back for repair/replacement, I added additional relays to the box, to keep the high draw solenoids from powering thru the remote box.
The instructions said that the box could take 30amps, but I still fried an internal relay.
Old 10-04-2006, 05:41 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
There is a emergency method (although I only recommend it in a pinch..) for opening the doors if the battery ever goes to the happy hunting ground AND you have no access to it..(inside hood pop)
Get a Bud with a set of jumpers and CAREFULLY hook the power to the solenoid big bolt from under the car..to the jump vehicle..THEN hook the ground to any body part..and open a door (S) to gain access...
Doc
Innovations
Old 10-04-2006, 05:47 PM
Bryan59EC's Avatar
Doc
I think he is implying that his passenger side is working correctly.
That is the impression I get.
Bryan
Old 10-04-2006, 05:58 PM
docvette's Avatar
Wiki Edits: 12
Originally Posted by Bryan59EC
Doc
Bryan
Doc here,
At first , I did too..but ...
HE doesn't indicate left or right just that you can't open them..
HOWEVER , if it is one side only..Simple..check the power to the left solenoids from the RF unit..or MCR..follow that up with a ground check on that side..you may have to install wire braid between the door and door posts..
Doc
Innovations
Old 10-05-2006, 08:42 AM
yes
my two pasenger side doors do work and i finaly fixed the front driver door but what about the back driver side
Fast Low Buck Shaved Door Handles Ron M Body - Exterior 18 07-24-2011 12:47 AM
How'd you do your shaved door kit.... JhnBrackett Body - Exterior 20 12-11-2005 01:29 PM
confused on shaved handles 78 King Cobra Body - Exterior 3 07-26-2004 10:57 PM
shaved doors? 6speedwagon Body - Exterior 2 03-22-2004 07:29 AM
How to make home made shaved door latches? Fordy8man General Rodding Tech 0 10-17-2003 03:47 PM
