Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - shaved door kit
Thread: shaved door kit
Old 10-01-2012, 06:56 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
What you'll need is the wire dia for the one you have. You should have a +12v in and a ground to the brain and maybe a few other wires......then the brain should be split out via a couple of connectors or one connector with many wires etc....... if all you are going to use are the door poppers, then you need to locate the Hot wires for each side etc..... mount your solenoids in the doors and run a ground from the popper into the cabin and ground it to the kick panel. Don't use the door as a ground. Run your hot wire from the brain to the popper etc...... I'd use a boot to transition from the door to the "A" pillar, I also use 14 gauge extension cord to make my wiring runs to doors..... triple insulated and very weather proof.
