Shaved Door Locks - Replace or Not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2010, 09:27 PM
kbuhagiar's Avatar
47 Plymouth Special Deluxe
Hello folks,
I need some opinions and observations.
The previous owner of our 47 Plymouth had the door locks removed (shaved). (The exterior door latch handles are still there.) However, he never completed installation of the remote door lock system.
I may just complete installing the remote lock system, but I am also considering reinstalling the manual door locks so I have an alternate method of entry. Of course, the old lock cylinder holes in the doors have been filled in, and would need to be opened up again. My concern is the paint of this car is a 9.7 out of 10, and I would hate to mess it up.
How hard would it be to re-drill (or otherwise re-establish) the holes in the doors for the lock cylinders? If I am real careful, and protect the painted surface, could it be done without damaging the paint?
Or, should I even bother? I am a bit leery about relying solely on an electronic system for locking & unlocking the doors, and would hate to be caught locked out of our vehicle.
Please advise, and thanks in advance!
Cheers, Ken
Old 11-28-2010, 10:02 PM
73oldsman's Avatar
I think it would be hard to redrill the key hole and reinstall the door locks without the possibility of damaging the paint. Check out this link http://www.a1electric.com/Merchant2/...ct_Code=POP-R2 as an example of a pop system. Most, such as this one, have an emergency back-up access kit available in case of electrical failure.
Old 11-28-2010, 11:14 PM
My first thought is go scrape the electric locks and put the cylinders back in. But with a nice paint job, you are REALLY asking for trouble. If the guy did a kick butt job and there is no filler or even very little, you could pull it off without much trouble. But if there is poorly applied, thick filler, you could be in for a big mess. I say put the electrics in there and when something goes wrong down the road you can drill the holes out if you have to.
Old 11-29-2010, 07:57 AM
kbuhagiar's Avatar
Good point; never thought about the possibility of body filler.
Cheers, Ken
302 Z28's Avatar
Brian nailed it. If the door lock holes were not filled properly by welding a close fitting metal patch in the hole and skimming a very light layer of filler over it you could be in for a world of hurt with the paint. My thoughts are you should just go with what you already have and just complete the installation.
FWIW, my opinion on shaved door locks and handles is I don't like them. They look great on custom show cars but are really impractical for driver cars.
Vince
Old 11-29-2010, 10:53 AM
kbuhagiar's Avatar
Vince
Vince,
I agree with you 100%. This car was purchased with driving in mind, not showing. I'm very grateful that the door handles are still in place. Quite frankly, I completely overlooked the fact that the door locks had been shaved when we bought the car (not that it would have made a difference), probably because the door handles were still there.
It's been my experience that most of the car guys who lean towards shaving usually remove handles and locks, not just the locks by themselves. I'm glad the previous owner was the exception to the rule and exercised some restraint.
Cheers, Ken
Old 11-29-2010, 11:03 AM
302 Z28's Avatar
Ken, is it possible to pull the door panels and get a look at the patched area from behind? That may give you an idea of how it was patched. If it is a welded patch you may be able to drill it out and install the lock cylinders. Start with a small hole and step up slowly to the size need to limit damage to the surrounding paint.
Vince
Old 11-29-2010, 11:20 AM
kbuhagiar's Avatar
Vince
Great idea, Vince - I was hoping to remove them in the next couple of weeks anyway, to examine the remote lock solenoid installation, and to evaluate the possibility of installing power windows.
I will be posting a separate thread soliciting recommendations on power window conversion kits (Christmas is just around the corner, you know!).
Cheers, Ken
Old 11-29-2010, 08:56 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
My 59 has inoperable door exterior handles.
The key either opens the door or rolls down the window.
And of course, there is a "when all else fails" emergency release.
If you like the door handles working, but are concerned about the electric locks, I see no reason to not put in an emergency release.
Instead of opening the door (and some older models the interior handle will unlock the door) you could just pull a cable to actuate the door lock(s) mechanically.
If your interior release also unlocks the door, an emergency release here would work.
No need to buy a fancy emergency release cable set-----bicycle brake and shift cables work great, are very flexible, and easy to hide in a running board, frame rail or rocker panel
Old 11-30-2010, 06:46 AM
302 Z28's Avatar
The problem with emergency release cables is car guys know all the hiding places. Might just as well leave the car unlocked with the keys on the seat .
Vince
Old 11-30-2010, 08:09 AM
I think the kind of guys who would know were the cable release would be aren't the kind of guys who would steal your car. I may be wrong but that is how I see it.
Old 11-30-2010, 06:10 PM
302 Z28's Avatar
I'm not too sure Brian, a lot of times you know the people who will steel your car.
Vince
Old 11-30-2010, 06:19 PM
Bryan59EC's Avatar
Yes, BUT---As we all know----Any type of lock or alarm only keeps
honest people honest.
I have inoperable exterior handles------all glass is laminated(yes it is).
These are both theft deterrents---NOT theft proofing
Hidden electrical fuel pump kill-----deterrent----not theft proof.
If someone wants it bad enough, they're going to get it.
I can only attempt to get their arms cut up from getting thru the laminated glass
Radiator - Repair or Replace??? indy_85stariones General Rodding Tech 6 05-05-2010 10:16 PM
31 Ford - Replace felt window channels earlf31 Body - Exterior 3 02-24-2009 04:51 PM
Do I need to replace the crank arms classicgarage Engine 2 06-16-2008 10:42 PM
Need to replace all my stolen tools Blackdog Garage - Tools 20 12-07-2007 01:38 PM
replace a 5 speed with a 6 speed? dtprula Transmission - Rearend 3 12-17-2004 04:32 PM
