Shaving bumper bolts. What's the proper method?
A friend tried it once and eventually got fine cracks around the old hole position. Is there more to it than cutting the heads off and welding them flush?
They had this on Trucks the other day. I think on the copperhead project?? What they did as I remember it.
1. Make sure all surfaces to be welded are all clean of rust and contaminents. This would include an area larger than the washer inside the bumper. 2. Put a bumper bolt through the bumper and place a washer on the bolt inside the bumper. You may have to bend the washer so it sits flush to the inside of the bumper. Tac the washer onto the inside of the bumper. 3. Cut head off bumper bolt leaving square part to fit the hole in the bumper. 4. Place carrige bolt just under flush with the bumper, so you can fill the depression with weld, and tac it in. 5. Weld the bolt to the washer inside the the bumper. 6. Finish welding around the washer inside the bumper. 7. Finish welding the bold to the outside of the bumper, and grind smooth. 8. Repeat. The washer adds strength around the bolt, so the bolt should not deform the bumper. Welding the bolt below the bumper surface gives more weld surface so when you smooth it it still has plenty of metal, and more strength. I have not used this method but it makes sense, and would probably prevent those cracks you mentioned by distributing the force of the bolt, and more weld to hold the bolt. Hope that helps. If anyone else has some methods chime in, or correct me. |
Thanks Magnus. I could see how that washer would help.
My question with regards to welding the bolt to the washer on the inside of the bumper is : How do you then get the bumper bracket to sit nice and flush against the bumper or inthis case against the washer? Do you have to enlarge the hole in the bracket to allow it to slip over the weld?
That is a good question, but depending on how big the weld is you may need to open the hole in the mount a little bit, or grind down the welds a little if they are excessive. As I said this is a method I have yet to try. Saw it on TV, but it seemed to cover the concerns of the bolt pulling out, or cracking free by giving more surface area, and multiple weld points to distribute the stress.
I suppose the best source of info on this would be the show Trucks. I just emailed the show on their info email for printed directions or a link to them on the web. |
The weld would be ground smooth. The bumper would be moved out the thickness of the washer and weld but there should be more than adequate adjustment in most bumper brackets to adjust for this.
I've always welded them on the outside with no washer. And bolted to the car where they go. Never had one crack yet. Troy Last edited by troy-curt; 04-17-2005 at 07:54 PM. |
| Eliminating bumper bolts | Dale Sizemore | Hotrodding Basics | 15 | 01-17-2005 08:23 AM |
| proper method to take apart mustang IFS | bhj | Suspension - Brakes - Steering | 4 | 04-21-2004 11:20 AM |
| Bumper bolts in shear? | 5window | Body - Exterior | 3 | 10-20-2003 06:31 AM |
| Proper method of preparing/painting urethane bumper covers. | 4 Jaw Chuck | Body - Exterior | 3 | 03-25-2003 02:57 PM |
| Bumper Bolts | David McConnell | Body - Exterior | 3 | 01-30-2002 06:41 PM |
