i recently had 2 cars in the shop that both needed shaved handles. i have seen someone that didn't know what they were doing do it before and nearly ruined the door. it was caved very bad from the heat (i assume). anyway, i had a buddy of mine come over to mig weld both cars. he knows he had to keep it cool so he went slow only tacking a couple spots at a time until it was welded all the way around. the damn door still dented in. not real bad but bad enough. about a 8x8" area which i was able to work back out. the second car he did the same thing but only tacked it every 3/4" or so. wouldn't you know it, the damn door still dented in. he would only do 2 tacks at a time then cool it right away with the air compressor. is there some kind of secret here or something i am missing?? whats the trick??
This is not my expertise at all BUT I have helped the students at a tech school do about 7-8 of them over the last couple of years.
What we are doing to avoid the problem you had is BONDING a piece of metal in stead of welding. Than we grind with a 24 grit
spray two coats of epoxy and finish out from there as needed over the epoxy.
Long term this has held up good.
Like I said this is way above my skills so beware of above advice!
There are some killer places for bonding adhesives in customizing, that is for sure. If you do, bevel the edge of the metal,that will lesson the chance of a "ghost line".
If you are welding a hole, filling the hole with a piece of metal and then butt welding the seam, you can control it as you weld and end up with little to no warpage. But if you were to weld a piece OVER a recessed area like with a 1990ish Toyota pickup, you REALLY, REALLY have to go slow.
I have done that a few times, do you know how long I take to weld it? How about a DAY, that's right, I would take a day to weld it up. Two or three small tacks and then let it cool completely down. I mean cool enough to put your tongue on it and feel no heat. If you weld it that slow, you will be successful.
I think the problem is cooling with air right away.
For me that leads to nothing but problems. If you allow the weld to cool by itself, no compressed air or water, warpage is lessened...Eric
If it pops in and out, I believe you have oil canned the metal. I have ran into this at work while metal finishing many times. The best solution I have found is to find the area of stress and stress relieve it. The metal is probably stretched at some point. I am in the process of working at heat shrinking techniques. Since I am no pro bodyman, I am using 3M metal adhesive (part #8510) for just this type of work. Wish I had more info for you.
i warped 2 panels on my car welding in patches by cooling the metal down too quickly. After i stopped cooling it down i had no warpage problems at all, even with a higher heat setting on the mig.
i originally wanted to use adhesive but was talked out of it. i figured welding would be a better approach but since everyone is recommending the adhesive thats what i'll probably do from now on. just out of curiosity though, i'm going to have to try welding one more time and letting the door cool naturally. thanks everyone for all tips!!!
Forgot to tell you, if you bond after the adhesive dries grind any excess that seeped out off. Never want any filler touching this stuff.
BWK
Barry,
I have to ask. What happens if some of this adhesive comes in contact with filler? I have some small holes where I used adhesive to bond sheet metal plugs and it worked its way to the top of the hole. I have not sanded that area yet, and I was hoping that I could finish that adhesive flush and primer over it. But what if I needed a skim coat of filler? What is the correct way to do this? Thanks in advance.
I just wanted to add that I read your last post, but the problem is that these holes were embossed from the old trim, so they are somewhat lower than most of the surface. So I am thinking even if I grind it, there will still be some area of dried adhesive that could make contact with the filler if needed.
some of the adhesives like the acrylic type use an acid as a catalyst. this is the same reason you dont put bondo an top of self etching primer. best thing to do is scuff up the adhesive as much as possible and spray a little epoxy primer on it then when cured put your filler.
If you have a metal patch and grind off the adhesive to the edge, its so minor that no problem will occur.
A pinhole is not going to be a problem either.
So anytime you are unsure before applying a polyester type product spray a barrier coat IE; epoxy or 2K primer.
Two reasons why, The adhesive has a different expansion rate than the polyester so after a while the polyester cannot keep up and will lose adhesion and look like a large solvent pop bubble.
Thats why hood scoops fail to last.
Next reason is a two part liquid polyurethane such as Duramix or Pastomix is not porous and waterproof so the solvent from the polyester when transferring under normal expansion and contraction have no where to go and the polyester will again lose adhesion and bubble.
Now some of the lower end acrylics such as Fuzor and maybe 3M say you can apply filler to theirs. But would never chance it on a flat surface such as a hood. Sides maybe.
On some areas that I filled some quarter inch holes, the adhesive ended up slightly above the surface. I planned on grinding flush, DA and epoxy prime over. Is that going to be OK? I used 3M 8515 adhesive. Will it show down the road? The areas are on the side of the fenders and one on the roof post. After reading about movement on the last post, I wonder if this could be a real problem in a climate that goes from 100 to -30. I store my car in an unheated storage in the winter.
I thought you guys were paying attention!!!!
The welding process caused metal to shrink. PERIOD!!!!
cooling with air, water, or waiting all friggin day isn;t going to have much effect on the outcome. I prefer to cool the weld seam, if need be, with compressed air. It doesn't give me any problems, and you are better off cooling quicker rather than letting the heat migrate further into the panel than need be. If you will always make butt welds and work the weld seam, only along the heat affected zone, your problems will be eliminated. There's absolutely no reason to use adhesives. That's a cheap, production body shop, get in/get out method. Do it right the first time and forget it!!
and you are better off cooling quicker rather than letting the heat migrate further into the panel than need be. Randy Ferguson
Ferguson Coachbuilding www.metalmeet.com
I wish I would have read this thread two days ago! I made the perfect patch panel to weld in to shave my drivers door. I was so carefull in tacking it in and letting it cool. But I ended up having the same problem as the originator of this post, as soon as I welded it up it warped!
There is a reinforcement plate right around the warped area. It is very difficult to get behind it with a dolly. I was able to get some of the dent out but not all. HELP! How can I get this thing out? Can I put heat on it? How much heat, where do I concentrate the heat at? I have no experience in shrinking metal, so any advice would be greatly appreciated!
Those of you experiencing warpage....what kind of cars are working on? My only experience is on older cars (1950 and older) and I've never had a problem with this.
Kev,
Introducing heat to the panel will only make matters worse. The heat generated by the welding process, caused the metal to shrink within the blued area (Heat Affected Zone or, 'HAZ') In order to reverse the effects of the welding process, you must return the metal to it's relaxed state by stretching the metal along this HAZ. Never work the metal outside this area when dealing with a weld seam, or you will have a huge problem to contend with. If you have an obstruction, rather than using a dolly, you have to be resourceful and use a slapper or other thin, hardened piece of metal to resist the blows from the hammer or slapper you are using on the face side. I prefer to always use a slapper, as the contact area is larger, yielding much smoother and controllable results.
the cars i had problems with are a 97 eclipse and a 95 civic.
randy: does the problem get worse or better the thinner the sheetmetal gets and what would your plan of attack be if you were making or modifing something like a motorcycle tank where getting to the backside is impossible. with all the custom bikes these days i cant imagine that all these fabricators are making these real nice tanks just to weld them up and have them warp and deform. i am not a welder but i am more or less in the motorcycle business and i am just curious especially since i will be making some mods to my own bike this winter. any tips would be appreciated.
Hi Guys,
The new, thinner, high strength steels are definitely harder to work with than the old stuff, but excellent results are still attainable.
As for your bike tank, you always want to place your welds in an area that you can get to on the backside. When custom building a new tank, you will place the welds where you can get to the backside of them with a post dolly or planishing hammer. Again, you have to be resourceful and make your own tooling at times, but don't let that stop you. Bike tanks are normally built out of heavier metal than automotive body panels, and coupled with the high crown shape of the tank, distortion can be held to a minimun if care is taken. You normally leave the bottom of the tank to weld in last, allowing access to the welds from the underside of the tank.
Well I took a closer look at my 'screwup' last night. Turns out the whole area where the door handle was is now sunk 1/8" into the door! No matter what I do, I can't bang it out either! I really screwed up this one. I refuse to fill an 1/8" area with bondo on the viewable body of this car, not after all the hard work I put into it already. I think I am going to scrap the door. I hate to do it because this is a completely rust free door. However, the car in which this door came from was in an accident once before and it put a slight twist to the full door frame. So it also doesn't line up perfectly on my car, it is close but not perfect.
I have another rust free door stored at a friends house. I think I am going to start over on it, now that I learned something. Only bad thing is that I won't be able to pick up the new door until Thanksgiving.
Any thought to just leaving the shaved panels in tack welds rather than fully welding it up? With my welding ability, there is no way around a skim coat of bondo anyway, I just don't want to risk warping another door this bad again.
I guess I overreacted. I ended up cutting out the patch piece and was able to pull the depression back out of the door. I still have a very slight ripple that is less than 1/16" deep due to my inexperience with metalworking. Anyhow, I made a new patch piece and started to weld it in. This time I used the procedure described in this thread - one tack, then blow with air, another tack, blow with air, etc. So far I have a tack every 1/4" in and have had no warpage problems. I will be finishing it up this weekend by the same method as earlier - all tack welds until the seem is gone. I still need some bondo to cure the slight ripple, but I feel much better now that the depression is in a much more concentrated area and is less than a 1/16" rather than what I had before.
I've used the fusor adhesive on shaving handle's before,, and have not had a problem yet,, I always make sure the height of the patch is the same height as the surrounding metal, and make sure the edges of the patch panel are right at the edge of the door, so that way there's very very little gap, and then grind the top edge of the patch so it tapers inward, and then fusor it in.. I've not had a problem doing it this way yet,, I hope it stays that way..as it's very hard to weld some of the newer sheetmetal without warpage.. on classics I still weld...
"I mean cool enough to put your tongue on it and feel no heat."
My wife already thinks I loves cars more than her! Just what i need, wife walking in the garage and seeing me testing metal temps. LOL!
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
