Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - shaving handles
Thread: shaving handles
  #25 (permalink)
Old 12-04-2005, 11:24 PM
chadsbodyshop49119 chadsbodyshop49119 is offline
Custom builder and painter
Last journal entry: Another test fit of the axle
I've used the fusor adhesive on shaving handle's before,, and have not had a problem yet,, I always make sure the height of the patch is the same height as the surrounding metal, and make sure the edges of the patch panel are right at the edge of the door, so that way there's very very little gap, and then grind the top edge of the patch so it tapers inward, and then fusor it in.. I've not had a problem doing it this way yet,, I hope it stays that way..as it's very hard to weld some of the newer sheetmetal without warpage.. on classics I still weld...
