Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sheared screw to valve cover
Old 07-16-2012, 04:39 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
How tight were you torquing them?? You could drill and tap it to the next size then re-drill the valve cover flange to meet it, or do a backyard fix, clean it up good and filling the hole with JB weld or something similar, drill and tap it, it might hold. If the head is off you can take it and have it welded, drill and retap.
Semper Fi
