Sheared screw to valve cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2012, 03:57 PM
While torquing the screw to the screw on the valve cover closest to the distrubutor, I broke the head off of the screw. Tried drilling it out and ended up making the whole bigger and a bit more back than the original. Any suggestions on how to fill or retapping?
Old 07-16-2012, 04:39 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
How tight were you torquing them?? You could drill and tap it to the next size then re-drill the valve cover flange to meet it, or do a backyard fix, clean it up good and filling the hole with JB weld or something similar, drill and tap it, it might hold. If the head is off you can take it and have it welded, drill and retap.
Semper Fi
valve covers
700R4 flywheel dust cover screw size? Curmudgeon29 Transmission - Rearend 3 11-22-2011 04:53 PM
Breather/PVC valve in valve cover juiced66malibu Engine 3 08-02-2010 07:28 AM
th350 inspection cover screw size? Gladis Transmission - Rearend 1 11-02-2007 09:02 PM
Suggestions on valve cover pcv valve baffle please! 67 Deuce 4 Me Engine 4 04-04-2005 05:45 PM
PCV Valve - SBC - 50's style valve cover spudone Engine 4 10-03-2003 08:22 PM
