sheet metal gauge? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2003, 11:04 AM
Post sheet metal gauge?
Hello
Is 18ga or 20ga sheet metal a better choice for making body patch panels? If either will work, does one have the advantage over the other?
thanks.
Old 05-19-2003, 11:40 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
18 is a little harder to cut but otherwise I like working the heavier metal. Makes it a little more difficult to get into trouble than with the lighter gauge.
Old 05-19-2003, 07:57 PM
Post
If you plan to hammer weld/metal finish the panels in, you will need to match the gauage with what you are patching.
Old 05-20-2003, 05:06 AM
Dragon J's Avatar
Last journal entry: Harley/Fire
Post
agree w/above- 20 will form easier, but 18 will last... and last...!!! I too, prefer to match to panel it is installed in- same gauge will be more consistent.
Old 05-21-2003, 04:12 AM
Post
thanks for the help guys. I think the body is 20ga or thinner, not to strong [48 thames panel] so if 20 will work I'm going to go with that. I am going to weld it with mig so I don't think I can hammer weld it anyway,so I've been told.
