-   -   Sheet metal Gauge? (http://www.hotrodders.com/forum/sheet-metal-gauge-184207.html)
lamothe1 09-10-2010 12:56 PM
Sheet metal Gauge?
Does anyone know what gauge sheet metal that Ford used on the '34 Ford firewall? I want to slightly modify mine and would like to use the same gauge so I won't keep blowing thru it while doing the welding.
Rollinsmoke 09-10-2010 04:36 PM
Welding..
Not being smart or anything buddy but, if you are blowing through then you'll need to adjust the settings on your welder or adjust your welding methods/habits.
As far as that gauge goes I'm not sure but we normally use 16/18 some 11 gauge
