sheet metal questiuon - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2006, 11:38 AM
well i will be buying 20 gauge metal sheet to shave some stuff .. but i call to the local metal sheet provider and they say they have just galvanized and black sheet metal. i know galvanized is not suitable for this but ..Is black the one to use??
Old 06-09-2006, 12:38 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Yes, It's bare steel with a "scale" finish that needs sanding off to weld or paint.
You can use galvanized as well for smaller patch panels and such. Use some muratic acid to eat the galvanize off and wash it thouroughly with water and a little baking soda to nuteralize the acid. It'll flash rust fairly quick though.
Old 06-09-2006, 12:55 PM
thnks then i going to buy the full sheet of black laminate
Old 06-09-2006, 12:56 PM
astroracer's Avatar
You don't have an old hood laying around? If not, a bent hood or decklid is cheap at a junkyard.
Mark
Old 06-09-2006, 02:01 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
If it were me, I would try and get cold rolled Steel-I believe the "black" stuff they have is Hot Rolled-it's not a lot of fun to get the black coating off-
Old 06-09-2006, 02:10 PM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Keep looking for other sources!!
Hot rolled will take forever to get it off. By the time you are done, its 22-24 gauge!
Galvanized isn't the answer either.
Old 06-09-2006, 03:15 PM
Shabby chic sheet metalshaper
A sheet metal shop I used to buy from called cold rolled steel "black steel"...check to see if this is the case where you are going.
John
Old 06-09-2006, 03:21 PM
I've never heard the term black sheet metal but I wouldn't think it would be hot rolled. I used to run a steel slitter and never saw hot rolled steel that was that thin. I'm not saying it couldn't be hot rolled but after working with steel for 22 years and not seeing any that thin I would have to doubt it. I also agree if it is hot rolled that it would be better to stay away from it.
Danny
Old 06-09-2006, 05:15 PM
so.. a cold rolled one is the one to look for ?
Old 06-09-2006, 09:51 PM
The cold rolled steel would be the best. It has a much smoother texture than hot rolled. Hot rolled would have a real dull look to it.
Danny
Old 06-09-2006, 10:41 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
home depot and lowes carry it around here or go to
www.metalsdepot.com
even with shipping they are cheaper then HD or lowes
Old 06-09-2006, 10:47 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Unless I see a need for a full sheet I would just use a piece of metal from an old car body or hood..Shaving door handles only requires a small piece of metal..
Sam
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Metal Finishing, let's talk about it. MARTINSR Body - Exterior 29 04-19-2011 09:47 PM
Metal Finishing, to quote the great philosopher NIKE, “Just do it”. MARTINSR Body - Exterior 17 12-24-2005 12:08 PM
Sheet metal how thick spikes_50 Body - Exterior 3 03-20-2003 04:28 PM
The woes of finding sheet metal... Sanspants Body - Exterior 12 03-03-2003 12:39 PM
