Sheet Metal Rust Repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2007, 09:56 AM
James Turney's Avatar
Moderation is not a virtue
Does anyone know how to form sheet metal for repair panels? My '49 Studebaker pick-up has rusted corner pockets on the rear of the cab. I would like to replace these with new sheet metal pieces. Not filled with Bondo! My welding skills are good for not warping the metal. Any suggestions would be helpful.
Thanks
James
Old 10-02-2007, 07:42 PM
metal
Google Ron Fornier he has a good book on metal working. Also Ghia specialties.com. It takes a LOT of practice to get really nice panels. I made decent ones with home made slappers and sand bags. They still got some bondo.
Old 10-02-2007, 07:49 PM
30desoto's Avatar
Dodge ain't all bad
I myself ain't to good at shaping either, but a good suggestion is take lots of pictures and measurements then visit your local recycle yard and find the corners you need from a truck and cut the corners out then you can come close to match with only a little bondo.
30dee
Old 10-02-2007, 08:12 PM
1930u's Avatar
Last journal entry: 1930u more fuel line plumbing
Thanks
James
I knew nothing about it either but have made every piece for my old plymouth. If you make them you need drawing quality sheet metal as it forms very easily. A radius gauge is also handy if your making panels with compound curves/radius. It took me awhile but I did it. I've used everything from a tree to a piece if water main to form panels. Give it a try if I can do it anybody can.
Old 10-03-2007, 03:40 AM
This might not be what your looking for, but it might help, anyway.
http://www.1969supersport.com/sheetmetal.html
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
Old 10-03-2007, 08:56 AM
Thanks for all the advice, it will come handy for mt truck. I cant wait to get started!!
Thanks again
James
Old 10-03-2007, 10:32 AM
Dejavu's Avatar
Not so New Member
Last journal entry: Trying to make a custom valance
You will learn a lot at metalmeet.com they have some guys over there that create some amazing stuff, and they are very willing to share their knowledge.
Good luck,
Fred
Fiberglass Rust Repair F3RR3T Body - Exterior 1 10-02-2007 02:21 PM
Rust, metal work, sanding, Paint!! 1970Chevy Body - Exterior 9 06-28-2007 07:00 AM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Wild Harold's Automotive Sheet Metal HAROLD DAVID LOVETT Introduce Yourself 2 09-28-2005 06:47 PM
Rust 50% Metal 50% Moby302 Body - Exterior 11 09-21-2003 08:40 PM
