Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sheetmetal buckle
Old 06-24-2009, 08:59 PM
Mike H Mike H is offline
The founder of metal meet shows using soap for the galling in his DVD and the watter should steam when you have enough heat.
You will have to hammer and dolly the shrink out of it because it pulls up quite a bit when you heat it with a torch but you only take about 50% of the shrink back out with the hammer and dolly. So it takes a little bit to get the desired result but the filler is minimum when you are done.
