Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Shelf life of Acrylic Enamel
Old 01-03-2013, 06:45 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Originally Posted by cyclopsblown34 View Post
Does storage temperature make a difference? I store my materials in the shop and it doesn't get below 70 degrees but will hit whatever the high temp is n the summer. I remember ages ago when i was a parts guy with a mixing bank, we were told to don't let the material get below forty degrees.
Storage temperature does make a difference, if the temperature remains at a fairly constant temperature that would make the paint last longer in the can. If your temperature range is a constant between 70 and a bit higher, temperature should not be a factor. One of the previous posts also mentioned that you have 1/2 gallon of paint in a 1 gallon can...he is correct in opening the can to make sure it hasn't skinned over. If it hasn't, shake it up and try it on a test panel.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
cyclopsblown34 (01-04-2013)
