Shelf Life for Hardner and Primer Cataylst - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2005, 07:10 AM
68Camaro396/375's Avatar
How long does this stuff last after it's been opened? I have to redo my spoiler because the color match was off. It's been almost 4 weeks ago.
Old 05-01-2005, 08:39 AM
willys36@aol.com's Avatar
Wiki Edits: 21
It'll last a long time. I have opened cans that are over a year old. You will know when it goes 'bad' 'cause it will be a solid chunk at the bottom of the can!
Old 05-01-2005, 09:29 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I'm not going to say exactly as some seem to last longer than others.
One thing that helps is to replace the cap tight right after using,Don't let it sit open as your mixing and shooting.
Besides the chunk, it will "seed" which as described will look like seed's in it.
If it looks OK, It usually is. Being a month,if it hasn't been opened much,you should be good to go. Mix it up and spray a test piece and see before shooting the good part/panel,You'll know in a short time if it's OK.
Old 05-01-2005, 09:35 AM
Thanks guys.
Old 05-01-2005, 03:50 PM
A good thing to do to make paint last longer is to put the can upside down once when you are storing it. Juist make sure to close the top really tight or it will fall on the floor. I have put some gallons of paint like that 1 year ago and they still seems to be really good.
When you put it that way, the paint seals the opening and no air can get in. My uncle told me that trick a couple years ago and I am really thankful to him .
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
using primer question AdamZx23 Body - Exterior 21 02-16-2005 11:53 AM
Old School - Black Primer Look - Paint Guns primerbaby Body - Exterior 11 02-06-2004 05:59 PM
good primer over ok primer hoss Body - Exterior 1 09-17-2003 02:28 AM
Sealer reaction with primer? TurboS10 Body - Exterior 10 04-02-2003 05:50 AM
