Shell Rack - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 03-07-2007, 07:37 PM
Shell Rack
Hi, I have a few back burner projects: 69SS396 El Camino I've owned since 73, an 88 Fiero (the best one), and an 89 Corvette roadster, all needing somekind of work.
I was recently looking for a rack for my Dodge Ram's 8' shell (a Leer). Something less than a construction rack, but something that could hold say a couple of kayaks. I found and installed one. It's alot cheaper than a Yakima, and a lot better looking and it fit perfect without cutting. Anybody need info on this?
Hawkeye2
Old 03-07-2007, 08:33 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders.
willys has rack and pinion davedeltadog Suspension - Brakes - Steering 5 03-31-2013 10:24 AM
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Shell Rotella T new formula and solid flat tapped cams. 71javelin Engine 27 02-01-2007 09:09 AM
Door skin installment sevt_chevelle Body - Exterior 17 01-20-2007 06:35 PM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 12:53 PM
