Sherman Transmission broken teeth - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2011, 01:51 PM
Is it possible and recommended to repair two broken sections of two separate teeth on a transmission gear? This is the out put shaft on a Sherman Step-up transmission from an 8N Ford tractor.
Who could do such a job?
Thank you.
Old 01-12-2011, 09:17 PM
rfuchs,
It is possible but it is not practical. You can buy a used shaft cheaper than what it would cost to have your repaired.
Scholman
Retired
Transmission (broken) cooler line fitting extraction 78 monte Transmission - Rearend 1 10-21-2007 03:36 AM
Shall I use Glasurit, PPG or Sherman Williams World? Quarter Flash Body - Exterior 2 10-10-2007 08:23 PM
Sherman Williams Clear Coat Failing < 3 Years? DeJarnett Body - Exterior 33 12-11-2005 11:39 AM
Broken timing light or broken truck? powerwagon Electrical 6 12-02-2003 07:48 PM
how many teeth does my flexplate have? 7fastelc0 Engine 5 11-07-2002 08:21 PM
