Sherwin Williams 4th Dimension Paint? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2009, 08:07 PM
Anybody ever use Sherwin Williams 4th Dimension Paint? Any opinions?
Thanks, Ray
Old 11-16-2009, 08:31 PM
mitmaks's Avatar
Last journal entry: Grille
it's lower end paint. What are you painting?
Old 03-24-2010, 06:33 PM
I'm considering using it for an overall paint job on my 68 LeMans (GTO Clone) Convertible.
What is good and bad about it?
Old 03-24-2010, 06:50 PM
mitmaks's Avatar
It's cheap....I wouldn't use it on a show car but if you're just doing a cruiser it would be fine. It doesn't cover as well as higher end paints ie PPG's Deltron.
I used PPG's Omni (their lower grade) and I liked it compared to SW.
I just prefer PPG paint.
Old 03-24-2010, 08:01 PM
Rag top bird's Avatar
Hot rods are still the king
I have used it before and I can say it does not cover well and I painted the car all over then the car came back with a dent so I did the repair and they could never match the color the tint base are not consistent if you are looking for a cheap paint then I would go with (Dupont)Nason or (PPG)Shop line
Old 03-24-2010, 08:07 PM
Thanks for the reply.
I realize that DBC is a better paint, and if it was 2x as expensive I would not think twice about using it. Unfortunately, in the color (red) I am thinking about using, it costs over 5 times as much. I don't recall the exact prices, but I think the SW cost about $130 per gallon and the PPG about $650 per gallon. If I recall correctly the the Omni cost about 2x as much as the SW.
I understand that the SW Dimensions does not cover as well, as top line paints and may not match as well (should not be an issue with an overall) but is the DBC worth over 5 X as much.
Old 03-25-2010, 06:23 PM
see if you can find gentec base or automotive art \
gentec is alot better than omni about same price
automotive art is like sikkens one of the best bases ever but priced so much lower
Old 03-25-2010, 06:42 PM
One of my "problems" is that I live in a rural area with no big cities nearby. Not a lot of options to buy locally, several places that sell Dupont or PPG and one that sells Sherwin Williams. The SW store only carries the dimensions line.
Are there online places to order some of these other brands?
If so, who/where?
I plan to use SPI Universal Clear and have already purchased it.
Thanks, Joel
Old 03-25-2010, 06:56 PM
CQNRQY
Thanks, Ray
Ive used it, It's similar to PPG's Omni
It's priced cheep and covers poorly compared to higher end paints
All the companys have an economy paint. You can get a respectible paint job with them all, but you usually need more product to get good coverage.
I'm an experienced painter. I'm doing fargo in pieces with Omin plum crazy a having a H*#L of a time . Wish I'd never let the owner talk me into using the stuff. Can't get the pieces to match each other.
I will likely end up doing a complete after assembly.
Are you an experienced painter?
If so you'll be abill to do it. If you're a beginner you'll end up with runs, tiger stripes, wet and dry spots, ETC.
A paint that covers easier and stays were you put it (such as a base clear) would save you $$$ in the end
Old 03-25-2010, 07:31 PM
I have some, but not a lot of experience. I have done some panel painting and I have painted about 8-10 vehicles, most of them, quite a while ago, using laquer. I used PPG DBC and PPG clear on the last paint job I did.
I have a new Devilbis Plus Gun to use for this project.
I will be using Base/Clear, regardless of the brand I choose.
Old 03-25-2010, 07:47 PM
Who sells these?
Old 03-25-2010, 08:59 PM
automotive art is a premium paint line relabled sort of like sikkens
gentec is from lucid tech they are out of utah.
I have used both and they are great. The automotive art being the best. Coverage is usually 2-3 coats. Color match is second to none
the gentec is a good base also just one step below the automotive art
Old 03-26-2010, 05:17 PM
CQNRQY
You shouldn't have any problem then
Base clears are very easy to use.
The base colour sprays similar to laquer the shine comes from the clear coat put over the base colour.
Good choice
Good luck & have fun
Old 03-27-2010, 09:26 AM
boatbob2
Paint...
HI,take the above advice on brand of paint,then shop EBAY,ive got some great deals on paint.(not junk paint,top of the line paint)
Old 03-27-2010, 09:46 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
you use 2nd line paint you will have a 2nd line paint job. there are many 1st line brands at less cost that perform good. i have switched to prospray . gal of blue cost me 230 .
sherwin williams hotrod black? runn141 Body - Exterior 6 05-08-2014 01:08 PM
6 layers of paint stu_yoakam Body - Exterior 7 10-06-2009 11:10 PM
4th Dimension base coat mitmaks Body - Exterior 2 10-18-2006 03:41 PM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 10:26 PM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 10:41 PM
