Any conductive cover on the wire will work, so long as you ground this shield. The metallic tape is fine so long as it's continuous and you can connect a wire to it to ground it. There is also an overbraid product that's sold at electronics supply houses that is exactly for this purpose. It looks like the stainless braid on hoses but the material is copper with plating or silver.
If you don't ground it it will make things worse. Make sure you only ground it in 1 spot. If another ground fails somewhere you don't want that ground tape trying to carry any serious current or you will have a fire. It will also work better if it is coiled around your wires rather that run along side of them.
Chet |
| new welding wire | oldred | Body - Exterior | 93 | 05-07-2009 04:40 PM |
| Help with Digital Dash Install | jvgrago | Electrical | 4 | 05-16-2008 07:16 PM |
| 4 wire alternator?!?!? | ProjectSuperNova | Electrical | 8 | 02-14-2005 03:11 PM |
| Where the resistor wire supposed to go ? | Olds 69 | Electrical | 33 | 02-08-2005 01:10 AM |
| 85 s-10 distributor wiring question | strracer7 | Electrical | 1 | 09-29-2003 03:39 AM |
