shift adjustment screw on TH350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2006, 08:01 PM
sabino56's Avatar
Just a quick question on adjustment screw for TH350
I was able to turn the screw a little and it moved the shift point in the right direction but I'd like to do a little more but I couldn't easily turn the screw and didn't want to strip the head
Is there a lock nut or something which you need to loosen before adjusting? If so, what and where?
What kind of head is screw? a flat or phillips?
Thanks!
Ed
Old 11-23-2006, 08:44 PM
Crosley's Avatar
Wiki Edits: 1659
Thanks!
Ed
flat type screw driver.
you can take a piece of wire like a coat hanger.......cut off a piece of wire, pound the wire end flat. FILE it into the shape of a screw driver and use that to adjust the screw inside the modulator nipple where the hose plugs onto.
Old 11-23-2006, 08:57 PM
poncho62's Avatar
Wiki Edits: 5
Which way do you turn the screw to up the shift point, Cros?
Ontario Rodders
Old 11-23-2006, 08:59 PM
sabino56,
I use the screwdriver that came with my glasses repair kit.
Scholman
Old 11-24-2006, 07:28 AM
Crosley's Avatar
Wiki Edits: 1659
As you look at the nipple on the modulator , turn it clockwise.
this preloads the spring more.
I have turned the screw in so far that it unthreads. You can feel the screw skipping, then I backed it out 1 turn.
YMMV
Old 11-24-2006, 09:32 AM
sabino56's Avatar
Thanks for posts!
Ed
TH350 - adjust shift point? sabino56 Transmission - Rearend 6 11-19-2006 06:16 PM
What will a TH350 Handle? Many Th350 Quetions, Shift kits? Warrant Transmission - Rearend 2 12-18-2005 09:46 PM
Stall wrong, transmission shift adjustment, suggestions? frankenvette Transmission - Rearend 3 10-26-2004 11:59 AM
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 03:15 PM
late 2-3 shift in th350 with transpak joeyg329 Transmission - Rearend 2 07-19-2003 03:32 PM
