shift flare - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2008, 10:13 PM
shift flare
What causes 2/3 shift flare in a 700r4?
Old 02-05-2008, 05:35 AM
31 five window
Last journal entry: grill and rear end
What do you mean by SHIFT FLARE?
Old 02-05-2008, 07:13 AM
shift flair
If you mean a slight spin up in rpms when it makes a 2-3 upshift, then if the trans is stock, that would mean not enough TV pressure.
As in, the cable is not adjusted correctly. Do the other upshifts seem to ocurr sooner than they should?
And don't forget, 3-4 clutch failure is very common, with this trans. The 3-4 clutchs apply on the 2-3 upshift.
Old 02-05-2008, 07:14 AM
When the trans shifts from 2 to 3 it revs up and then goes into gear. When it goes in its fine. The more I'm in it the worse it is. Is there a proper name for this condition?
Old 02-05-2008, 07:30 AM
I rebuilt the trans a few months ago and have just recently been able to use it. It's a little better than stock, and my clearances are within spec. The upshifts come in a little later than they used to. I'm talking like 2 or 3 miles an hour later. I have a corrector kit on the way for my carb. Would the tv cable be a likely cause, or is it something else.
Old 02-05-2008, 01:36 PM
shift flare
There are a lot of things that can cause a 2-3 flare.
Worn vb in the TV area, damaged seals in either the input drum or the servo, too much clearance in the servo.
Drilling the 2-3 feed too large in the separator, just a bunch of stuff.
Old 02-05-2008, 04:04 PM
Thats what I was affraid of. I'm hoping it's the cable cause I'm waiting on my carb corrector right now. If its not that I'll see about the servo next.
Old 02-10-2008, 07:35 PM
Hey guys. I adjusted the cable and it shifts like it's supposed to. I still have the 2/3 shift flair but only when I'm in the throttle pretty hard. It does fine if I'm just easing around. Could that be the servo?
Thanks
TH 350 1-2 Manual shift Feel HarderTranz Transmission - Rearend 3 05-16-2006 09:20 PM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 10:21 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 09:08 PM
Tranny shift problems. chevcamz28newbie Transmission - Rearend 6 08-09-2003 05:52 PM
