Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Shift kit..........
Old 08-07-2002, 04:15 PM
Centerline Centerline is offline
Wiki Edits: 49
Post
Yes. All you need to do is drain the fluid, remove the pan and valve body and install the kit. Be carefull not to lose any of the little ball bearings and just use a little petrolium jelly to hold them in place when reinstalling everything.
Centerline
http://www.hotrodsandhemis.com
[ August 07, 2002: Message edited by: Centerline ]</p>
