Shift Kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2005, 05:51 PM
Blazin88's Avatar
New Member
Shift Kit
How hard would it be to install one of these B&M shift improver kits in my 70 Chevy Pick Up 2wd with a th350? What all is involved? Will it harm the trans if its not installed right? http://www.bmracing.com/index.php?id...t=12&subcat=21
Old 10-25-2005, 08:18 PM
Drain the fluid, pull the pan off, pull the valve body off, drill some holes, & mess with some springs...then put it all back together. It isn't really that hard to do if you follow the directions. Yes you can screw stuff up if it isn't done right.
need AOD shift kit advice murrsue Transmission - Rearend 5 09-16-2005 09:04 PM
slight clunk/ shift kit install Q's HARVICKx29 Transmission - Rearend 2 02-16-2004 09:51 PM
TH700r-4 shift kit 85CHEVY Transmission - Rearend 6 11-14-2003 09:18 PM
my tranny wont shift hard even with shift kit notmrgoodwrench Transmission - Rearend 4 08-12-2003 06:10 PM
Stick shift conversion kit cvc505 Transmission - Rearend 1 08-16-2002 09:43 PM
