-   -   Shift kit.......... (http://www.hotrodders.com/forum/shift-kit-9052.html)
Blue_Blazer 08-07-2002 02:54 PM
Shift kit..........
Ok,#1: I am the laziest SOB on earth.
#2: I want to know if you can install a shift kit with out dropping the trany?
Why you ask,see#1
Centerline 08-07-2002 03:15 PM
Yes. All you need to do is drain the fluid, remove the pan and valve body and install the kit. Be carefull not to lose any of the little ball bearings and just use a little petrolium jelly to hold them in place when reinstalling everything.
Centerline
http://www.hotrodsandhemis.com
[ August 07, 2002: Message edited by: Centerline ]</p>
Blue_Blazer 08-07-2002 05:09 PM
You rule! :D thats just what I wanted to know.
Now if I'm lucky a Summit will have the kit I need in stock.
