Shift kit.......... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2002, 02:54 PM
Talking Shift kit..........
Ok,#1: I am the laziest SOB on earth.
#2: I want to know if you can install a shift kit with out dropping the trany?
Why you ask,see#1
One littel reck and nobody even got killed,whats the big deal?
Old 08-07-2002, 03:15 PM
Wiki Edits: 49
Post
Yes. All you need to do is drain the fluid, remove the pan and valve body and install the kit. Be carefull not to lose any of the little ball bearings and just use a little petrolium jelly to hold them in place when reinstalling everything.
Centerline
http://www.hotrodsandhemis.com
[ August 07, 2002: Message edited by: Centerline ]</p>
Old 08-07-2002, 05:09 PM
Cool
You rule! thats just what I wanted to know.
Now if I'm lucky a Summit will have the kit I need in stock.
