Shift kit or manual valve body??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2008, 08:35 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I am about to get after the rebuild of my T-400 in my street rod..I am undecided on going with a shift kit or a full manual valve body..Enlighten me on this..and why either one would be better or more fun or better performance..
Thanks
Sam
Old 03-07-2008, 12:25 PM
RE Shift kit or manual valve body???
Hi l've always went with the B&M stage 1 shift kit, shifts hard(bang) when you got your foot in it and nice when you don't, stage 1 is with no modulater valve, so you get the same results as a clutch without the knee workout, and there cheap $56 here, the price has came down on them, 15 years ago they where double that, there really easy to install, kind of idiot proof, so that thats good for me!! TROY
Old 03-07-2008, 01:18 PM
life is a temporary assignment
I find the Shift kit's are better for the street,
Old 03-07-2008, 01:30 PM
shift kit or manual vb
A full manual valve body, is a drag, in a street driven vehicle.
Having to shift everytime you stop gets old fast.
I would recommend a Transgo shift kit, which will allow you to hold the trans in first gear as long as you want, and will also give you nice crisp automatic upshifts.
Old 03-07-2008, 02:40 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Shifting can be a drag, but for a 4 speed fan, it's not an issue and the control is nice to have. I first tried the TransGo kit in my T-400 and had issues on the 1-2 shift, this was on a blower car, but I could never get it to shift under 3k, twice along side the local gestapo right downtown; he must have been a fan, he acted like he didn't even see me, and the blower with short run Borlas were trying so hard to get his attention! Rather than messing with reprogramming springs at the governer, I put a Hughes full manual forward valve body in, locked out the gov, used some of the parts from the TransGo kit and made some additional modifications. One thing to be aware of with a full manual valve body...it'll drop right into first if you tell it to, that'll get your attention real fast.
What you can live with is personal preference, but like Briscoe said, it can be an inconvenience if you don't like shifting.
Semper Fi
Old 03-08-2008, 09:35 AM
Wiki Edits: 3
Thanks guys ..helps me make a decision..
Sam
Old 03-08-2008, 04:19 PM
DeathRattle's Avatar
Some Punk Kid
I really like my full manual valve body. I have been told it will wear a pump faster and I believe it will with all the pressure. I let off the gas when i want to shift so i wont put my head through the back window it shifts so hard.
The best benefit for me has been in the snow. I can use 3rd gear to take off from a light or stop sign and I have a lot less slip and slide unless i want it.
Another benefit is the installation, very simple.
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 01:49 PM
Bad Valve Body? HawkZ28 Transmission - Rearend 2 02-26-2008 08:55 PM
TH 350 1-2 Manual shift Feel HarderTranz Transmission - Rearend 3 05-16-2006 10:20 PM
AOD Valve Body ?s mustang66maniac Transmission - Rearend 3 03-15-2003 03:12 PM
manual valve body question cuda66 Transmission - Rearend 2 02-10-2003 06:11 AM
