shift kit in Mustang - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2011, 01:43 PM
With a Mustang AT and a 302 v8. Does a shift kit weally make difference?
Old 04-19-2011, 01:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A properly designed and installed shift kit can increase driving enjoyment and performance. It can also help to reduce transmission wear in an otherwise sound tranny- BUT it's NOT a cure for a worn out or broken tranny.
Some shift kits have different "levels", like RV/towing, street/strip or full competition. Whatever level you may choose, be SURE you stick to just the mods needed for that level- DO NOT "mix and match" mods or parts between the levels unless instructed to do so!
Some shift kits allow the gear manually selected to be held until the shifter is used to select the next gear, and will allow the tranny to be downshifted at any RPM- something that you should be aware of to avoid possible damage by over revving or loss of control by the rear tires locking up under engine braking.
Old 04-20-2011, 04:05 PM
Mustang shiftn kit
Thank you kindly
Column Shift to Console Shift lonestarrodz Transmission - Rearend 1 06-04-2006 01:03 AM
need help on converting column shift too floor shift . jody chevelle Electrical 1 11-29-2005 09:29 PM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 11:21 AM
th400 early shift/ soft shift 69er Transmission - Rearend 3 11-15-2004 08:16 AM
my tranny wont shift hard even with shift kit notmrgoodwrench Transmission - Rearend 4 08-12-2003 07:10 PM
