shift kit and rebuild indication - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2010, 09:24 PM
I aquired a tranny and the guy said it has shift kits. well tonight i open the pan and i can see where someone has drilled some holes bigger and there was only 2 balls is that common? btw the tranny had a large tci sticker on the top of the tranny. I checked the fluid and there was some shavings but how can i tell for sure if it needs rebuild? Does the tci shift kit have only two balls it came with a 1800 stall. Could u help me determine if this tranny has a shift kit. what are some other clues
Old 05-13-2010, 09:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Any clue what make - model the transmission is?
Old 05-13-2010, 10:08 PM
I am sorry its a 350 turbo erly 70's model i believe and the motor is a 327 10.5 to 1. The cam is a solid flat tappit 525 lift and a 3000 stall rearend is a 8.5 gm 10 bolt 373 gears and posi
Old 05-16-2010, 10:23 PM
Reword what i am asking
What i am trying to ask is if theres a way to determine if a 350 turbo needs a rebuilt while out of vehicle? Also I am wondering if 2 balls in the valve body is heard of? I know three usually with a shift kit and 5 orignal.(I think)
Old 05-22-2010, 10:14 PM
I know when I installed my shift kit it only had 3 balls, and still has 3 with shift kit. also a th350 from 70's. I thought it was 1 ball per gear though, was just estimated guess for me though, but made sense to me.
But ya, 3 in mine
Old 05-23-2010, 03:33 AM
scrot's Avatar
What is the purpose of those check balls anyway?
Old 05-23-2010, 06:54 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Remove the pump for a proper inspection of the internals is a better way to determine of a rebuild is needed.
there are 4 check balls in a non lock up t-350, 5 in a lock up design t-350c
Check balls perform a function as the name applies.. they stop fluild flow through a hole.
Check ball may direct fluid in one direction in a bath tub shaped cavitiy in the trans with two holes located over this cavity.
A t-350 needs only 1 check ball to operate an automatic shifting trans.. Getting into custom built valve bodys and there may be no check balls used
Old 05-23-2010, 08:20 PM
Thanks guys, i apprechiate you guys replying. I will pull the pump out but if i do that, will i be able to put it back in without a problem? I want to take it complete to a tranny shop. So two balls and if there holes drilled out then i do have a shift i wonder if theres a way to know exactly what i have? Also when pulling this pump off what are some things i need to know and also what am i looking for?
TH-350 shift kit/TH-400 rebuild Caprice Sleeper Transmission - Rearend 1 04-15-2010 07:47 PM
4L60E rebuild kit ????'s Turbonoma Transmission - Rearend 0 04-14-2007 12:10 PM
Please help me find T-350 rebuild kit, what do I need? Warrant Transmission - Rearend 9 05-04-2006 10:46 PM
shift kit rebuild kit help roy383ci Transmission - Rearend 1 03-26-2005 07:17 AM
TH700r-4 shift kit 85CHEVY Transmission - Rearend 6 11-14-2003 09:18 PM
