Shift Linkage - Does this look right? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2010, 07:41 PM
I think i've got this right. Converted this truck (79 C10) from 3 on the tree manual to TH400, including pedal and column swap so I had nothing to look at to make sure it was right.
Things fit pretty snug. Is there supposed to be a washer between the hairpin and the bracket on the side of the trans where the shift lever attaches to? The linkage wont stay put without the pin, and with the tension on it i'm afraid it might chew through the pin eventually without a washer there.
Old 03-05-2010, 07:53 PM
32Essex's Avatar
I would take the shaft out and drill another hole in it 1/8" below the original and rotate it 90 degrees, then you can have a washer.
Old 03-05-2010, 08:15 PM
ericnova72's Avatar
More for Less Racer
You might be able to squeeze a thin AN washer in there if you feel you need to, but IIRC from the factory is just like you have it - no washer, just the hairpin spring clip. The factory clip was a custom sizd clip that was a little more compact than the clip you are using, smaller loop sections but the same basic shape.
62 Impala column shift linkage ? DADDYOOOOH Transmission - Rearend 3 03-24-2008 10:33 AM
Loose shift linkage? Mertz Suspension - Brakes - Steering 4 02-06-2007 02:54 PM
Header collector in way of column shift linkage Warrant Engine 4 08-29-2006 01:26 PM
best way to adjust shift linkage? lemans-tom Transmission - Rearend 2 09-08-2005 03:54 AM
shift linkage dusterbd Transmission - Rearend 5 09-15-2002 12:00 PM
