is this shift linkage postions the same for the 4L60e? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2011, 12:37 PM
old yukon's Avatar
I couldn't find an image for the 4l60e, but found this.
Is the Shift Linkage the same for all 7 position (P,R,N,OD,d, D2,D1) ?
Meaning, if you turn the bolt to the far left its D1, and to the far right its Park.
Old 05-26-2011, 02:14 PM
Roadsire's Avatar
Last journal entry: Dash mods
SHift lever
I have a 700r4 and it should be the same I don't have a shifter in yet but installed the B & M lever the other night and it is as your picture shows and should be the same for your 4l60. if the tranny is installed if you put it in park (foward or on the left side as in your Picture) and rock the car forward you can hear and feel the lock pin engage hope this helps
Old 05-26-2011, 04:17 PM
tnsmith10's Avatar
when will it rain???
arm goes down, stub on the end facing IN towards the pan, and the furthest point forward at the bottom of the arm is park. i also hope for your sake that you filed the edge on the manual shaft where the prndl switch slides over. if you dont, you stand on breaking the inside of the switch and it will not work properly.
Old 05-26-2011, 08:26 PM
old yukon's Avatar
thanks for the feedback!
All was filed when I was working on the tranny waiting for parts.
tnsmith10 do you mean like this:
Old 05-27-2011, 08:59 AM
tnsmith10's Avatar
yep! thats the way it goes.
just one thing, there should be 2 10mm head pan bolts that go to the pan that are just for that shift bracket. if you dont have then in the right place, you can break the case. ok?
Shift Linkage - Does this look right? Torque454 Transmission - Rearend 2 03-05-2010 07:15 PM
Loose shift linkage? Mertz Suspension - Brakes - Steering 4 02-06-2007 01:54 PM
Shift Linkage starman141b Transmission - Rearend 3 12-22-2004 06:19 PM
shift linkage dusterbd Transmission - Rearend 5 09-15-2002 11:00 AM
Coverting TH 400 shift linkage Sandman Transmission - Rearend 1 06-09-2002 03:08 PM
