Shift linkage question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2010, 01:02 PM
I just picked up a 65 Chevelle with a ZZ4 engine and TH350 trans. The current shift linkage is a B&M ratchet shifter (which I hate). I want to switch to the origonal column shift. The only conversion kit I can find is from Shiftworks". Has anyone ever used one of their kits? If so how good does it work, ie:do you change the detents in the column or can you only shift the trans into 2nd gear (old low gear position). If anyone knows about this kit or knows of another kit that works good I would appreciate any info.
Old 07-12-2010, 01:26 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The column shifter mechanism has enough travel to go from Low to Park w/a TH350. There are gear indicator lenses for some Chevys to change from a PG pattern to a TH350/400 pattern. Check @ Shiftworks.
EDIT- Same place as your shift linkage kit.
I have no experience w/the kit you mentioned.
Th350 Shift Kit Question leejoy Transmission - Rearend 15 03-16-2006 01:33 PM
SMG.. paddle shift formula 1 style transmission question beemdubya Transmission - Rearend 2 09-10-2005 09:07 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
B&M Pro Shift question? frankenvette Transmission - Rearend 3 06-11-2004 12:16 PM
Camaro shift linkage problem chevcamz28newbie Transmission - Rearend 2 07-21-2003 02:01 AM
