shift manual vs automatic 700R - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2004, 10:49 AM
I purchased a shift kit that offers a manual shift only option withit. What might be the pros and cons of going this route? Would this affect the rest of the setup, wiring and torque converter (lock up vs. non lock up?.........thanks for the replies in advance......................
Old 05-19-2004, 01:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
ful manual 700 is best to be non lock up or a manual control on lock up.
that way when you shift through the gears from neutral to first the converter clutch does not apply if set for auto-lockup in OD
