Is the shift pattern on a ford c3 and a c4 the same? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2011, 09:36 AM
Last journal entry: Albany Oregon Show
I need a aftermarket floor shifter for a street rod that will work on a Ford c3. I have looked everywhere I know to look and all I could find is the stock wrecking yard stuff, not acceptable to the customer. I do not know if a c4 shifter will work. I know the bolt pattern is different on the two transmissions, the c4 has 11 bolts and the c3 has 13 bolts. I don't mind fabricating a few brackets to make it work, but if it is not feasible we will have to swap it out for a c4.
Bob
Old 06-16-2011, 03:53 PM
SSedan64's Avatar
Probably not many Pintos, Mavericks etc.. left in Oregon.
I read somewhere that a shifter for a C4 will work but, I know nothing about Ford Trannys. I'm sure someone will chime in with more Info.
Ford Bolt Pattern 4.25 inch? 31fordcoupe Suspension - Brakes - Steering 21 10-29-2009 02:44 AM
anyone know how to make a reverse shift pattern 727 valve body? the nitro man Transmission - Rearend 0 06-13-2009 11:18 AM
ford 9" 4 3/4 lug pattern the dan Transmission - Rearend 11 10-18-2007 05:40 PM
Reverse shift pattern brainsboy Transmission - Rearend 3 06-29-2004 02:51 PM
shift pattern of a 1949 chevy 2 door KMurphy Hotrodding Basics 2 05-23-2004 06:37 PM
