shift point - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2013, 06:00 PM
shift point
I recently rebuilt my 700R4. It has the .500 TV Boost valve and .300 reverse boost valve. I reused the same vette governor that was already in it. My one complaint with the unit is the full throttle shift points. It has the transgo hi rev springs installed to hold 2nd gear without burning the 3-4 clutches. It also has the hi rev pump slide spring to hold full pump volume. But, unless I manual shift, it shifts from 2nd to 3rd at 5,500, which is too low for my motor. I manual shift at 6,300, which is about perfect. As is, it won't shift from 1-2 below 30mph. It has been this way since it was first built 14 years ago. I am thinking about removing the springs from the governor. Will this raise the minimum 1-2 shift point even higher? If so, how can I raise the full throttle shift points without raising the minimum 1-2 shift speed? I feel very good about the results of this build. For my first 700R4, I am pleased with how it turned out. This is just fine tuning. All of the help that I receive here is greatly appreciated.
Old 07-06-2013, 12:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
its been my experience on the 2-3 shift in a 4l60... the spring on the 2-3 shift valve needs changed. SLight changes make big difference in road speed - RPM shift point.
Ounces on change is all that is needed. Stiffer spring will hold off the upshift to higher road speed.
Altering the governor often affects other shifts points more than the 2-3 shift point. You get the 2-3 where you like, the other shift points are then out of whack to your liking
Old 07-09-2013, 08:59 AM
Thank you again for your help. I was wondering about the 2-3 shift valvetrain. I'll look at a slightly stiffer spring.
Old 07-11-2013, 07:05 AM
pricesgarages's Avatar
ive always had good luck with a governer from a 2.8 s10 it rasies the shift points a bit on 1-2 but 2-3 are good
Old 07-12-2013, 08:55 AM
I did a test this morning, making a full throttle run through the 1-2 and 2-3 shifts in D. The 1-2 shift was at a perfect 6,300 right where I manual shift. The 2-3 was again at 5,500. This proves Crosley's point concerning the shift valve spring versus the governor. I'll work on this as I get the chance.
th350 shift point zoomo Transmission - Rearend 4 09-11-2010 01:28 AM
shift point zoomo Engine 2 09-06-2010 02:46 PM
Late shift point bct Transmission - Rearend 2 05-27-2005 07:59 PM
Shift Point sb72elcamino350 Engine 0 01-29-2004 08:59 PM
TH400 shift point...help Ted655 Transmission - Rearend 1 10-14-2002 11:18 AM
