Shift points & Governors - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2013, 09:22 PM
Last journal entry: getting started
So I have a 455 with a Th400, when I bought it years ago it shifted fine with the stock engine. Now I have the 455 built a little better than stock with some extra cam... The previous owner had changed some of they governor weights to shift to his liking. Now with the additional HP I feel it shifts way too soon with both easing out of a stop or even when I squish the carpet.
My question... Will putting in lighter weights in effect both conditions like I want it too?
I would like 1-2 to be at about 2200-2400 under normal driving conditions and 4000-4500 WOT
And something along those lines for 2-3.
But what the hell do I know?
Blast away!
Thanks,
Jerry
Old 10-12-2013, 09:59 PM
ericnova72's Avatar
More for Less Racer
B+M Transmissions sells a "Governor Recalibration Kit" Part # 20248 for the GM transmissions...it does exactly what you want to do...it is more than just weights, there are springs between the inner and outer flyweights to balance part-throttle shifts with WOT shift points..
Governor Recalibration Kit for TH-700R4, TH-400 & TH-350 | B&M Racing and Performance Products
Old 10-13-2013, 06:41 PM
Thanks...
I also feel the rpms are a little high at highway speeds just toolin along...
Old 10-13-2013, 09:08 PM
Taller tires or higher (smaller #'s) rear end gears are the way to change the cruise RPM unless un have the money to install some kind of overdrive.
200r4 shift points willys36@aol.com Transmission - Rearend 4 01-03-2012 12:10 AM
the Shift Points Midnight Run Transmission - Rearend 1 07-31-2009 10:39 PM
Shift Points??? What to do thiems Transmission - Rearend 11 04-09-2003 05:45 PM
C6 Shift Points leefc Transmission - Rearend 9 11-01-2002 08:35 PM
C-4 shift points 5.0 Fury Transmission - Rearend 1 07-30-2002 11:48 AM
