-   -   Shift RPM's by Gear for 700R4 Trans (http://www.hotrodders.com/forum/shift-rpms-gear-700r4-trans-222655.html)
Hawkfan 08-07-2012 05:46 PM
I'm installing a programable shift light on my new TCI 700R4 trans. Would anyone know what the shift RPM's should be by gear? I'd like to get some bench mark set points before I road test.
Thanks in advance.
the california kid 08-10-2012 12:56 AM
hawk fan
i'm guessing you're trans is a Ford product and
you have a 4.6 SOHC engine.
set the shift light at 5000 rpm and
then go up by 100's.
whatever the best time is over a 1/4 mile that
is your shift point.
have a nice day!
302 Z28 08-10-2012 09:55 AM
Thread title say's it's a 700R4:rolleyes: I have my 700R4 shifting at the engines max advertised HP RPM under WOT which is around 5800rpm.
Vince
Croz 08-12-2012 11:19 AM
My understanding is it has more to do with your motor than your transmission. For example, SBC is going to have a different red-line and shift point than a BBC, and you could run either through the same transmission.
327NUT 08-12-2012 03:28 PM
Oh no Vince, the guy has one of the VERY rare 700R4 Ford Variances....:spank:
geezer69 08-12-2012 03:42 PM
id figger where the peak is then go a little past it to let the rpm's be just a little better in the power range when it shifts.
