Shift RPM's by Gear for 700R4 Trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2012, 04:46 PM
I'm installing a programable shift light on my new TCI 700R4 trans. Would anyone know what the shift RPM's should be by gear? I'd like to get some bench mark set points before I road test.
Thanks in advance.
Old 08-09-2012, 11:56 PM
hawk fan
i'm guessing you're trans is a Ford product and
you have a 4.6 SOHC engine.
set the shift light at 5000 rpm and
then go up by 100's.
whatever the best time is over a 1/4 mile that
is your shift point.
have a nice day!
Old 08-10-2012, 08:55 AM
302 Z28's Avatar
Thread title say's it's a 700R4 I have my 700R4 shifting at the engines max advertised HP RPM under WOT which is around 5800rpm.
Vince
Old 08-12-2012, 10:19 AM
Croz's Avatar
Hotrodders.com moderator
My understanding is it has more to do with your motor than your transmission. For example, SBC is going to have a different red-line and shift point than a BBC, and you could run either through the same transmission.
Old 08-12-2012, 02:28 PM
327NUT's Avatar
Oh no Vince, the guy has one of the VERY rare 700R4 Ford Variances....
Old 08-12-2012, 02:42 PM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
id figger where the peak is then go a little past it to let the rpm's be just a little better in the power range when it shifts.
700r4 wont shift out of first gear illegal regal Transmission - Rearend 33 02-08-2009 07:32 AM
700R4 won't shift out of 1st gear metalhead2910 Transmission - Rearend 15 09-24-2008 06:04 PM
700r4 won't shift out of first gear RPM Transmission - Rearend 5 08-16-2008 07:17 PM
700R4 will not shift into 3rd and 4th gear bebopwally Transmission - Rearend 14 05-25-2006 07:48 PM
More Info, High RPM to Shift on 700R4 Ted Bundy Transmission - Rearend 3 11-25-2003 05:44 PM
