Shift selector lever worn on 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2013, 01:36 PM
Hello I have a 700r4 in my impala and the shift selector lever on the left side of the trans is also sloppy on the shaft. I had initially attempted to adjust the cable because it wasn't hittingall gears properly. The sshifter is a B&m mega ratchet shifter. So I noticed the selector lever is all sloppy as the rectangular hole is worn bigger then the key on the shaft. My question is should I change the lever or both the lever and the shaft? And if so, how do I get that shaft assembly out from the transmission? I already have the pan off so Yea. Any help is appreciated, thanks.
Old 04-06-2013, 07:27 PM
700r4
If the shaft doesn't appear to be worn, I'd just replace the lever. I've had several do that to me over the years and have had good luck just replacing the lever. Best of luck.
Old 04-07-2013, 11:25 AM
Wiki Edits: 85
If the new lever does not tightly fit the shaft, just remove the internal nut and swap out shafts.
aod selector lever half_fast Transmission - Rearend 17 02-09-2011 04:32 PM
700r4 shift lever problem kbyounger Transmission - Rearend 1 05-02-2008 07:04 PM
Automatic Shift Lever Mertz Suspension - Brakes - Steering 0 08-10-2007 09:56 AM
C4 Shift lever problem BT74 Transmission - Rearend 6 05-07-2006 06:01 AM
87 Fiero Shift Selector Cable Fiero Freak Transmission - Rearend 1 05-15-2003 01:59 PM
