Shift Shaft Seal Tool - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2007, 03:36 PM
The shift shaft seal in my C-4 Transmission is leaking a lot, so I am going to replace it. My question is - will either the GM or Mopar external tool work? I really don't want to drop the pan if I don't have to. An earlier thread talked about the tool being used on a TH-350, but made no mention of the C-4 or other Ford tranny.
Old 02-18-2007, 03:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the shift linkage design on the C4 trans requires the pan & valve body to be removed to install a new seal.
Steering shaft seal 1939d2/s10 Suspension - Brakes - Steering 3 08-12-2006 08:25 PM
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 09:08 PM
New Scan Tool user 36scsc Electrical 3 01-29-2005 07:35 PM
Tranny shifter shaft seal leaking????? M&M CUSTOM Transmission - Rearend 6 03-22-2003 04:19 AM
T-350 Long vs short shaft change zachscc Transmission - Rearend 2 01-21-2003 01:53 PM
