shifter help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2010, 10:26 PM
shifter help
we are replacing the powerglide with a 350 turbo. Shifter linkage does not work. what other linkage can i use? we have the column linkage.
Old 08-16-2010, 08:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You can see what Shift Works might have to let you keep your PG column shifter and use it w/a TH350: http://www.shiftworks.com/kugel.htm
You could hunt down the console and shifter for your '64. Might want to get bucket seats while you're at it.
Otherwise, an aftermarket floor shifter would be a natural.
Old 08-16-2010, 10:25 AM
Cape Cod Bob's Avatar
Try Lokar. Google it.
Old 08-18-2010, 07:05 AM
shifter help
thank you all
Old 08-18-2010, 11:34 AM
What do you mean the shift linkage "doesn't work"? It should work fine, except that you won't be able to manually access first (low).
Old 08-18-2010, 03:19 PM
I agree ...
I made this swap for a friend some years ago and had no problems getting the original shifting mechanism to work. P - R - N- D - D2 all worked ... just could not get the Turbo 350 into D1.
I did have to readjust the neutral start switch ... IF ...
I remember correctly.
Old 08-18-2010, 07:17 PM
302 Z28's Avatar
Be advised that the Lokar is not the best choice if you have any drag racing in mind. They are next to impossible to shift correctl while under WOT.
Vince
Muncie truck tranny shifter popped out of place? Barrybomb Transmission - Rearend 12 02-16-2009 03:43 PM
Pontiac Powerglide shifter 67malibu Transmission - Rearend 2 12-17-2008 02:49 PM
ST-10 Hurst Shifter jamming Brimstone Transmission - Rearend 1 08-11-2008 04:47 PM
What automatic shifter is good novadan Transmission - Rearend 3 02-23-2006 11:45 PM
Automatic shifter in pickup floor? newchevyman Transmission - Rearend 5 09-02-2003 07:48 PM
