Shifter installation/replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2005, 06:44 PM
New Member
Hi all-
I have a B&M Megashifter that recently gave up the ghost (the "trigger" broke away from the part that it connects to down in the shifter). I have ordered a B&M Z-Gate to replace it. How hard of a swap will this be? I don't believe I'll even have to crawl under the car, will I? I've never replaced a shifter before, but since it had previously been converted from a column shift to the Megashifter, most of the hard work should already be done. Can anyone give me a heads up on what kind of project I have ahead of me? Thanks in advance!
Old 05-30-2005, 06:57 PM
72CutSupreme's Avatar
New Member
I could be wrong but I'm fairly sure you won't have to crawl under the car. You should just be able to uinbolt the shifter, remove the cable from the old shifter, bolt it to the new shifter, and bolt the new shifter in place.
Like I said I could be wrong but I think it should be fairly easy swap.
Good luck
Dave
Automatic shifter in pickup floor? newchevyman Transmission - Rearend 5 09-02-2003 06:48 PM
Shifter ? speedo cable question western star Transmission - Rearend 2 08-30-2003 06:23 PM
5 speed tranny with forward shifter? Warm_Spit Transmission - Rearend 2 08-13-2003 08:09 AM
AOD Shifter Bezel? PaulW Transmission - Rearend 1 08-04-2003 09:06 PM
stock Ford shifter 5.0 Fury Transmission - Rearend 1 09-26-2002 03:36 AM
