Shifter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2009, 06:58 PM
Grubbworm's Avatar
G and V Racing
Shifter question
i have an automatic 81 chevy pickup with a messed up steering column so i bought a used steering column out of a 4 speed. What could i do about the shifter? Should i put a floor shifter in it or somehow put the shifter off the old steering column on the new one?
Old 09-09-2009, 07:08 PM
ericnova72's Avatar
More for Less Racer
Should have just bought the right column!!
Taking the two apart to swap pieces is a major PITA, worse than just fixing whatever was wrong with the original column. To use the stick shift column you will have to put some sort of floor shifter in.
Old 09-09-2009, 07:40 PM
S10xGN's Avatar
Gotta love a turbo!
You could probably come out ahead on this, the floor shift columns are a lot harder to find and worth more. If you're not in a hurry, find someone looking to go with a floor shift and swap them for their column shift setup + $$$.
Russ
Old 09-10-2009, 01:03 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I'm going to move this to General Rodding Tech.
Dan
aftermarket shifter question Wolfdog General Rodding Tech 4 08-10-2009 03:24 PM
Pontiac Powerglide shifter 67malibu Transmission - Rearend 2 12-17-2008 01:49 PM
ST-10 Hurst Shifter jamming Brimstone Transmission - Rearend 1 08-11-2008 03:47 PM
b&m shifter kit question idid35 Transmission - Rearend 2 11-18-2003 06:45 PM
Shifter ? speedo cable question western star Transmission - Rearend 2 08-30-2003 06:23 PM
