Shifter ? speedo cable question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2003, 12:32 PM
western star's Avatar
I put in a Hurst Indy 3 speed floor shifter in my truck and the main part of the shifter is about 2 inchs away from where the speedo attaches. Even if I had the room to hook it up the cable would be running straight through the main part of the shifter. Is there a gear attachment that is an elbow or something that would kick this out of the way. Why would Hurst make a shifter that eliminates the speedo? A 4 speed is in the distant future but for now I would like a speedo. Thanks...
Old 08-30-2003, 04:59 PM
BOBCRMAN@aol.com's Avatar
Angle adapters are available at a speedo shop, the trans shifter either has a "universal" mount or the wrong one.
Old 08-30-2003, 06:23 PM
All fixed up. I simply move the shifter back an inch and drilled a new hole and everything works.
