Shifter or Trany ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2012, 08:02 PM
Shifter or Trany ?
I am restoring a 1976 Camero LT and I bought it with a Quicksilver Automatic shifter today it slipped out of drive and and i could rev it like nuetral then i put it in nuetral and then back in drive and it shifted back fine but when i would get in a higher rpm it would do it again and again. I thought a trany rebuild but could it be in the quicksilver shifter? I no nothing about it i called the manufacter and recived a insulation manuel on line but it has nothing for trouble shooting. So Trany or Shifter ??
Old 10-16-2012, 07:23 AM
SSedan64's Avatar
May need to drop the Pan & see if the internal shift linkage is tight. Check the external shift linkage on side of Trans 1st.
need som e help
shifter tower, shifter rail and shift fork diagram needed! Chris Kemp Transmission - Rearend 0 02-12-2009 05:59 PM
trany help!!! dcweld Transmission - Rearend 1 07-05-2005 10:57 PM
trany 390xw Transmission - Rearend 6 03-16-2003 12:14 AM
new trany Camaro350 Transmission - Rearend 2 07-24-2002 10:00 PM
Low on trany oil.... sliping trany? BadBowTie Transmission - Rearend 2 03-10-2002 07:34 PM
