shifter vibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2011, 02:52 PM
shifter vibration
This is my first post. I have been using info on this forum for awhile and now decided to look for a little assistance on a small issue.
This is a new 468 BBC, Muncie 4 speed, Hurst shifter. EVERYTHING is new.
For those of you with high compression big blocks and Muncie type 4 speeds, is it common to FEEL the motor through the shifter? I ask it this way because I dont want to call it a vibration. The motor is smooth on the dyno and in the truck but I always feel a rumble\shake in the shifter as I pass 2500 RPM. This is in gear, in gear with clutch in, in neutral and while stopped.
Old 04-12-2011, 04:07 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Did you install a new clutch kit and if so did you have the flywheel re-surfaced ?
Cole
Old 04-12-2011, 05:08 PM
Everything is new, except the seasoned bare block. No vibration at all with engine clutch and bell, no trans installed. As soon as I plug in the trans I feel the symptom. Can't be the pilot as it does it clutch engaged and dis-engaged. I think it might be normal big cam solid mount shifter vibrations. Anyone with first hand experience?
Old 07-16-2011, 08:57 AM
Anyone have any thoughts on this?
Old 07-16-2011, 09:07 AM
evolvo's Avatar
Heathen
Maybe there are bad bearings in the trans.
Old 07-16-2011, 07:18 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Yes to this within reason.
68 Camaro 383 vibration in shifter. Ropper Engine 20 11-11-2010 04:50 PM
shifter tower, shifter rail and shift fork diagram needed! Chris Kemp Transmission - Rearend 0 02-12-2009 05:59 PM
383 vibration hammerdown Engine 6 06-15-2007 09:21 PM
350 vibration caminoguy55 Engine 15 01-28-2004 09:10 AM
vibration markiemyster Transmission - Rearend 4 11-30-2003 11:13 PM
