Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - shifting hard
Thread: shifting hard
Old 03-11-2002, 08:31 AM
NOVA JEFF NOVA JEFF is offline
Post
Need more info,what trans is in vehicle? Suggestions! Ck for trans leaks if loosing fluid, repair. If trans has kickdown cable could be streched or out of adjustment,if trans has vaccumn modulator, it could be defective allowing trans fluid to be sucked up through vacumn line to intake manifold and burning the fluid through exhaust,pull line ck for fluid,vac line may be cracked insufficient vac. or modulator is bad
NOVA JEFF.
