shifting problems on turbo 400 tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2006, 01:32 PM
ok i just started to work on these trannys and well i have boughten a truck with 350 with turbo 400. the truck will shift when the tranny is cold and will move ok.. not like it should. when the tranny gets warm or you drive it about a mile it stops shifting and i have to let it cool down to get anywhere. can anyone give me some ideas on what the problem is with the tranny.. thanks alot..
Old 04-04-2006, 02:22 PM
Hi Akstonedborder,
Sounds like you have an internal problem. Check your fluid and see/smell if it is burnt, if so you might want to pull the trans pan and see what kind of debris is in there. This is usually a strong trans but if the plates are worn badly they will loose grip do to excess clearance between fibers and steels and start to slip or not hold at all, also you could have worn/torn lip seals in the drums/pistons and will hold as long as fluid cold (thicker) and after warm up fluid is thinner and will by pass seals.
Jack
Old 04-04-2006, 03:13 PM
tranny has been rebuilt recently
i have checked all the fluids. the tranny has synthetic tranny fluid. the fluid doesnt appear to smell burnt or look burnt. some one had mentioned to me about a bolt loosening up and making so it wont shift. the tranny shop here told me to pull the pan and check all the bolts. thank you for the reply
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
tranny problems denny 9577 Transmission - Rearend 3 12-29-2005 05:28 PM
turbo 400 vs 700R4 864x4 Transmission - Rearend 3 10-03-2003 05:28 PM
What problems should I look for in a 400 sbc? stonedchihuahua Engine 8 11-05-2002 02:36 PM
7ooR4 vs 400 turbo? WBhunter Hotrodders' Lounge 4 04-25-2002 01:54 PM
