Shifting ? regarding a TH350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2010, 05:43 PM
Madmax305's Avatar
Hey guys I just installed a Hughes GM30 3000 stall on my TH350 which is mated to a mild built 350 with a comp magnum 270 cam. The car drives and idles sooo much better, but now the car shifts like grandma's car. Would a shift kit make for better shifts and if so, which one? Why did the high stall effect the shifting of the transmission? Before the high stall, it had a crisp shift to it. Any thoughts?
Old 11-23-2010, 10:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Higher Stall speed converter softens up shifts... that is part of the action from a stall speed converter to get the engine into a higher RPM.
This is common.
When you get the engine RPM up high the shifts should be much firmer.
SHift kit wise.. I suggest TransGo blue box .... t-350 1&2
I would use the firmer shift settings since you have that GM-30 converter
Old 11-23-2010, 10:51 PM
Madmax305's Avatar
This is common.
Thanks for the information Crosley....
Shifting on a TH350 ryno2287 Transmission - Rearend 2 07-02-2009 12:54 AM
TH350 shifting problems 1985CHEVYCARLO Transmission - Rearend 8 04-08-2009 10:44 PM
late shifting TH350 red_rider52 Transmission - Rearend 18 12-19-2005 10:32 PM
TH350 Warm Shifting Problem thurr Transmission - Rearend 4 11-08-2004 01:01 PM
TH350 WOT shifting eball Transmission - Rearend 1 09-05-2003 11:09 PM
