Shiftkit needed if have transbrake? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2005, 11:53 AM
Hello,
I was curious if it would do any good if you install a shift kit with a transbrake?
Thanks
Trent
Old 01-06-2005, 12:36 PM
Mr Ed's Avatar
shift kit
definetley install a shift kit if you are going to the trouble of installing a trans brake. The trans brake is to assist the launch from the start line. A shift kit firms up and speeds up the actual shift through the gears. I would choose the shift kit over the trans brake if i could only afford one. The trans shop will tell you which shift kit will complement your trans based upon the weight of your vehicle (i.e too hard a shift and break traction etc). Install a trans oil cooler too if you haven't got one cause trans brakes heat them up.
Old 01-06-2005, 05:24 PM
Hello,
It is a 1972 El camino, and will weigh about 3600 with me in it. It has 4.56 12 bolt rearend, and a wicked sbc 406!!!!
Thanks
Trent
Old 01-06-2005, 08:16 PM
Crosley's Avatar
Wiki Edits: 1659
Cool
A transbrake vave body is already set up for maximum performance shifts since a trans brake is primarily for drag racing
Old 01-08-2005, 05:58 PM
Cool, sounds like I just have to buy the transbrake.
Thanks
Trent
Old 01-08-2005, 08:06 PM
Crosley's Avatar
Wiki Edits: 1659
Cool
Depending on the tranny , they need special attention to internal parts for transbrake operation.
The torque converter needs to be built for transbrake operation to avoid 'ballooning" the converter
