shim head gaskets - sealer ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2007, 07:22 PM
DHMag's Avatar
i have a set of embossed steel shim head gaskets id like to install on my street 305. should i install them dry or use a sealer ? the only sealer ive been able to find around here is Indianhead Shellac, which ive used before with positive results . if i do need sealer, what is a good brand to use ?
Old 05-10-2007, 07:28 PM
Wiki Edits: 31
as a general rule, no sealer on head gaskets, only certin applications need sealer. shim gaskets were used on some ford engines ( 144-250 I6 they were factory ) W/O sealer, so I would say, sealer is not nessasary
Old 05-10-2007, 08:08 PM
BOBCRMAN@aol.com's Avatar
Back in the day. I used steel shim gaskets all the time. The best sealer is a spray can of Chrome aluminum paint. Two heavy coats on the gasket and assemble. NEVER had a leak..
Old 05-10-2007, 11:10 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
I know poeple that have used brake quit spray and copper spray when they reuse metal head gaskets. I dont think woul dbe any different unless it has some coating on it already. The main thing is to get the head and block flat and smooth.
Old 05-11-2007, 04:35 AM
Running the 1094 Felpro shim gasket in my circle track engine last year we just stoned off the block & head, checked flatness, and then sprayed both sides with the red hi-tach stuff. Worked for a whole season, don't know how it would have been 10 years down the road though!
Old 05-12-2007, 07:41 PM
Same here. It was what everyone did back in the day.
Old 05-12-2007, 07:49 PM
Chopt 48's Avatar
Yep, It worked well then although some of these new sealers may work as well or better.
Question about .015 head gaskets - FelPro 1094 surfshark Engine 2 03-30-2006 04:08 PM
ROL Head Gaskets MI2600 Engine 3 03-20-2006 08:44 PM
What head gaskets do I need Bryce Engine 9 03-01-2005 01:45 AM
Head Gaskets HotRodS10 Engine 4 08-13-2002 04:30 PM
400 SBC Head Gaskets MI2600 Engine 2 07-21-2002 01:41 PM
